slow hydraulic loader response on mx5800
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Disconnect the hydraulic couplers and reattach. A lift cylinder coupler isn't fully seated, restricting oil flow.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If your three point control is in the full up position this can cause the loader to be slow. Try backing it off a bit. If this solves your problem your rock shaft probably needs adjusted.
5,270
Good thought - just drop the 3-point down and try it.
Just a small correction - - probably Roadworthy meant Feedback Rod instead of rock shaft. Both are components of 3 point.
