TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Need some advice..I recently purchased a new BX1880, with a payloader. Used it to spread 15 yards or so of topsoil. I decided after that, it required a ballist box which was delivered today..Land pride BX10 box to be exact .Question, how much weight to you folks use and what source of weight do you put into the box? I was thinking bags of softener salt with some cast iron weight in the bottom. If, your using the machine for topsoil, how much weight do you add ? Also, how much air do you add to the front and rear tires when using the payloader ? Shop manual doesn't specify..
