ZD326 - RCK60P-331Z Deck Anti Scalp Casters
Bugeater
ZD326P, L-295 DT
Sep 1, 2022
OK
Does anyone have any tips or tricks on keeping the caster part of these front anti scalp rollers spinning freely? They have a grease fitting and call for #2 multi-purpose grease. That tends to attract dirt and eventually it will no longer caster and it will gouge the turf. I haven't had much luck re-greasing to free them up, they have to be taken apart and the dirt cleaned out. I have tried WD-40 instead of grease, not much better. I have tried dry graphite spray, a little better, but still only good for a few hours of mowing before they lock up again. To be clear the roller it self is not the problem. It is the caster portion that will lock up and not rotate as you turn. I think the manual calls it the front anti scalp roller pivot boss. Circled in blue in the photo.
3,667
2,087
It sounds like you are mowing with the anti-scalp wheels touching the ground like a gauge wheel. They should be 3/4" off the ground and rarely touch.
4,122
2,815
Are you talking wheels not spinning or the swivel?
I have the same problems with my wheels - uneven ground and crappy plastic bearings instead of metal roller bearings makes the wheels plastic bearings wear out too fast. My plan was to machine a set of old plastic wheels to press in metal needle bearings and possibly fab a new shaft?
Poor design on the part of K engineers IMHO. The rest of the mower is pretty bullet proof.
If they aren't swivelling then you made the shims too tight. When driving on concrete your swivel scalp wheels shouldn't be touching the ground.
