Hi all,
Picked up a '14 L6060 at a JD dealer... and also a JD MX6 brush hog. 2 pics attached.
Have it attached with a Quick Hitch, now when set the 3pt. to max height, you can see in the photos, it's only a few inches off the ground in the front while the wheel is still on the ground in the back. I can only lower the 3pt to about 6 1/2 before the front of the MX6 is touching the ground.
Looking at some videos online, I thought I would be able to lift the entire MX6, including the rear wheel, off the ground at max height at about 1ft. in case I need to maneuver over something.
Do I have something on my 3pt set wrong on my quick hitch? Or is this MX6 just not setup to get that rear wheel off the ground?
Thanks all!
Thanks all!
