Hi all, first time poster long time lurker!
I have an L48 and I’m experiencing a bit of a weird issue. I have several “data” points to mention, I don’t know if they’ll make sense, but the end all problem is that I don’t have full power on the bucket. After a while I can’t raise it at all, even at 2400RPM.
I flushed all the old hydraulic fluid and used UDT2. Old fluid was nasty, dirty and milky.
Replaced all the filters
Replaced all the hydraulic seals
Checked the relief valve on the front block, tightened it a little to increase pressure - no change.
New fuel filter - unrelated, but mentioning it.
Cleaned radiator and check anti freeze
Removed each line and flushed fluid to ensure nothing was stuck.
Observations:
Boom on the backhoe has lost almost all power, I haven’t replaced this seal yet. So I don’t know if it’s related.
At idle I cannot raise bucket nor backhoe boom
When I’m experiencing the slowdown and I curl the bucket down. The bucket doesn’t slam against the stops. This has made me believe there’s a problem with the return side of the lines.
If empty the bucket completely and rev it up to PTO indicator I can very slowly raise the bucket. I cycled it up and down several times and it does feel a little quicker on the way down after cycling it up and down. But it doesn’t speed up much and I still can’t pick anything up.
If I push the bucket down and curl down I am able to lift the front end of tractor.
I have plenty of pushing power. I just can’t lift anything.
Left right movement of the backhoe is very quick, compared to rest of hydraulics - I think this makes sense since it’s on the 3rd pump in the back.
What have I not done:
I haven’t removed the suction line filter, that’s on my list of things to try. Just don’t know if it’ll do anything.
I bought the service manual, which pointed me to the relief valve. But short of buying a new front pump, I don’t know what else to do!
Observations:
