I have a new project tractor
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
So, what I have now to add to the collection is a Ford 2810. I know it's a Ford but is a new to me project.
I don't know much about it other than it has set not running for at least 3 years, 3 flat tires, and a possible electrical issue. It comes with a bush hog, bottom plow, and finish mower.
Worst thing about it I have found so far is that both axle seals are leaking, a can of starter fluid in the tool box, and bad battery cables. The battery and starter are new.
Anyone possibly have a lead on wiring diagram or maintenance manuals that won't cost an arm and leg. I'll get some pictures posted when it's not raining.
LarryBud
L3130
Dec 5, 2020
241
127
Cleveland, MO
eBay for operator and workshop manuals. They should be reasonably priced. The workshop manual will have the wiring diagrams.
I just did the same with a 3600. It not a late model Kubota for sure but has its charm.
Should have ready access to parts. Post a pic Or two.
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
So far not so bad. The battery is to big, the fuel pump leaks from the throttle and shut off levers, the transmission is soup from water in it, and tires are kinda dry rotted.
It will clean up real nice though.
Pictures:
LarryBud
L3130
Dec 5, 2020
241
127
Cleveland, MO
Nice,
Horizontal exhaust, roll bar, power steering and those tires don't look all that bad from what I can see. Pretty sure they sell a gasket kit for the pump.
Let me know if you need to get into the gauges. I went through that on my machine and I can save you some time.
The_Wingnut
Grand L4060, ZD21, ZD28, ZD331, RTV X1100C, Branson 3820, JD 1020, JD 50
Dec 8, 2021
91
Tyner, NC
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
Nice,
So far the gauges work good. The plastic is not clear but I still read everything. Did you get into yours to fix the gauges or replace the lens?
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
Can't tell if there is a draw bar there or not. I have one if you need it...free just pay shipping.
I have one I found in the woods behind my house. Your very generous though and the offer is much appreciated!
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
This has the suspension seat on it and appears to be stuck or I don't know how to work it. Looks like the knob is rusted solid not allowing for adjustments. Is it supposed to turn or be pulled up or pushed down to make it work? Thanks
I'll get a picture when I get home today.
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
Draw bar I found in the woods behind my house and seat adjustment knob I don't know how to operate or it's frozen.
5,066
Pictures:
View attachment 103098 View attachment 103099 View attachment 103100 View attachment 103101 View attachment 103102
You will love that old Ford!
They are great machines!
I did a nearly complete restoration on my 1100 hour Ford 1920 FEL.
I use it much more often than my larger Kubota L48 TLB.
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
New radiator cap and new ignition switch. The one that was in it was generic and not working correctly. Yes, the new switch is a Kubota switch. I didn't like the replacement Ford switch keys.
Also is the Rhino FM72 finish mower I got with this tractor. The blades were upside down, fixed that and cut for the first time. It's not very smooth cause it's vibrating so bad. I took for granted that the blades were still new but one could have a problem.
Both axle seals, power steering, and injection pump leak at this point. Just shaking out the cob webs.
Just noticed that my top link U was upside down. That will make a difference...
mcmxi
6,344
NW Montana
Torinodan
Oct 14, 2021
199
94
Fayetteville GA
Very nice tractor! Looks like a great project for sure. (y)
Thanks!
I got the fuel pump leak fixed today or at very best extremely slow now. I also picked up a PTO log splitter! It's old and still works but going to see very little use with the rear exhaust this tractor has.
It is a Unicorn splitter. And I've only seen these in pictures and videos.
5,066
The draw bar I have is the one that actually goes under the tractor, exits below the PTO shaft. I'll try to get a picture of it.
Yup....
THAT is the real "draw bar" on these tractors.
5,066
Thanks!
View attachment 104053 View attachment 104054 View attachment 104055 View attachment 104056 View attachment 104054
I have that same style splitter..
Mounts on the left rear wheel of my stick shift 4x4 '77 Ford F-250
