The Kubota circuit is not cheap as an add on and is "bang-bang". If anyone has experience running a grapple off the remote circuit, I would like to hear your input.
Whats to know? It will operate fine but not as operator friendly as the solenoid valve with joystick switch.The Kubota circuit is not cheap as an add on and is "bang-bang". If anyone has experience running a grapple off the remote circuit, I would like to hear your input.
Cheapest option is to get the diverter kit where you split off from your curl/lift function. My experience, you will probably end up wanting to be able to curl/lift at the same time you open or close the grapple. True third function is well worth the money, in my opinion. If you start with it, you will most likely save money in the long run due to not buying the diverter and being dissatisfied at some point to end up with the third function anyway.The Kubota circuit is not cheap as an add on and is "bang-bang". If anyone has experience running a grapple off the remote circuit, I would like to hear your input.
Yea having to pull your hand off the loader control to close or open a grapple is not very user friendly.The Kubota circuit is not cheap as an add on and is "bang-bang". If anyone has experience running a grapple off the remote circuit, I would like to hear your input.
X2Yea having to pull your hand off the loader control to close or open a grapple is not very user friendly.
I find myself running lift, roll, and squeeze all in one motion and all at the same time.
I have run a grapple using a manual valve mounted just to the right of the loader joystick. It works fine but is not optimal. It was a quick and dirty way to get the grapple into service. I already had the valve and the means to mount and plumb it into the LA525 loader valve.The Kubota circuit is not cheap as an add on and is "bang-bang". If anyone has experience running a grapple off the remote circuit, I would like to hear your input.
If you are going that far just buy a generic D03 valve and plumb it off the loader valve. Close to the sane cost and number of hoses and you have "true" third function.Here’s a possibility:
