I checked that early on by removing it measuring spring pressure with kitchen scales and face diameter with calipers. Theoretically it opens around 65-75psi.One simple place you may look is the relief valve located in the oil filter housing. Not a place that you see problems very often but it does happen.
Edit: I just rigged up my compressor to test the oil sensor. It breaks the circuit at around 15psi
