I recently bought my first Kubota M5700 4wd Rops from an individual. I have noticed when working the 3pt hitch there’s a lot of travel and small movement that actually controls the lift. What I’m really concerned about is when I pick bush hog all the way up they hydraulic pump wont cut off unless you move the position control lever down about a inch or so then you can hear the pump cut off. Is that normal or is there some kind of adjustment to make the pump cut off when it’s lifted all the way up? Thanks for the help.
