B7500 with 5k hrs buying advice...
Wannadmaxsub
Found a B7500, unknow year for just under $4k. Tractor has 5k hrs. No attachments. PTO grinds when engaging, I have not seen it yet. This is all info from the seller. Is there anything I should look at that is a common (expensive) issue with these? Yea, I know...not knowing the year can make this difficult...but I'm asking anyway...
On edit...where can I find the data plate?
N3BP
Sep 20, 2016
505
236
Lebanon, PA
Personally I'd pass given the hours and issues. That machine was made in the early 2000's. You may have put as much money into it as your going to pay for it.
BAP
Dec 31, 2012
3,048
1,165
What is your intended use? With the hours on it, the PTO problem and no attachments, you would be better off looking for one that has no issues and some attachments of some kind.
Wannadmaxsub
Intented use is, mostly just dragging a harrow and land plane around (driveway, parking area and several paths are covered with rock)...the riding mower and the wifes little ATV aren't cutting it.
PaulL
2,640
1,617
NZ
If you don't need the PTO, and don't need a loader, then you may be able to get that machine cheap.
Personally, I wouldn't buy a tractor without a loader and a PTO that works. Once you have one it'll suddenly turn out that you have lots of jobs beyond pulling a harrow and land plane. A loader makes every job easier. The PTO lets you drive all sorts of implements - I drive my wood chipper, you could also potentially run a rotary cutter or flail mower. Perhaps a snow blower if you get snow.
3,682
Run, Forrest! Run!
Wannadmaxsub
Yea....I'm running, LOL. Started thinking about the projects I've done around here and decided a bucket would have made them much easier...and the PTO grinding on engagement could be an expensive fix. Thanks all!
9,533
The PTO grinding could be as simple as a clutch linkage adjustment.
But 5K (WOW) on a little tractor like that, it's seen a lot of use over the years!
5,183
Excellent decision!
Ackorange
M5400 4x4 with loader & hoe, box blade, old MF1010
May 25, 2023
Nantucket
I am not a genius, nor very smart! But many more hours over 2500 makes me very suspicious! Unless your a good Mechinic and think 800 to 1000 is A GOOD DEAL. I may want more but I'D LIKE TO=HE MOON! TOO.
