I bought a used zd221 with a 48” commercial deck. The deck height is way lower than the dial setting.
There are two issues. If I max out the adjustment bolts (screw them all the way in which raises the deck) it is still lower than what is set. For instance when set a 4” on the dial with the adjustment maxed it is maybe 3.25”.
If you follow what the manual says for leveling it puts it way lower.
The deck is also very clearly uneven side to side when the screws are set in, I would say maybe 1/4 to 3/8” off.
Nothing appears to be bent. Measurements at various points on the frame side to side are pretty close.
Part of me wants to get longer adjustment screws, the original is an M12 x1.25x45mm a 60mm would get me closer, just haven’t been able to find a full thread bolt at the same strength.
Any thoughts?
Any thoughts?
