Hi folks; I just installed a new oil pressure sensor (electrical) on my B7200. At the same time I changed the oil. I also added some HE Lucas oil treatment as this engine is about 35 years old. I checked on line and confirmed with the Lucas bottle that says to add 20% Lucas to your oil. I understood the oil pressure should be between 15 and 40 PSI. I also thought the Lucas would increase the oil pressure at the same time. After installing all this and test firing the engine, I'm getting about 46 PSI on the gauge. I also noticed a small amount of air in the pressure line to the gauge.
Any thoughts on the Lucas oil treatment, 46 PSI, and the air in the line would be much appreciated.
