When i jump the starter it will start. Where should i look next? Starter relay? I get a loud clicking under the dash and it puts a huge strain on my battery when i do not jump the starter
All connections have been cleaned, i put in a brand new battery. Is the solenoid behind the steering column inside the cab?I'd begin by cleaning battery cables and terminal ends tightening securely when done. Clean and tighten frame ground as well. If the problem persists after charging the battery monitor the battery voltage while attempting to start. You may find the battery is not up to snuff and due for replacement. If this does not solve your problem you may wish to consider a relay between the key switch and the solenoid.
What model of L4610 do you have as it makes a difference in the wiring.All connections have been cleaned, i put in a brand new battery. Is the solenoid behind the steering column inside the cab?
