BX2670 starting question
itsaz
BX2670, FEL, Box Blade, Wood Chipper, Rotary Cutter, Disc Harrow
Oct 14, 2016
59
17
Wichita Falls, TX
I seem to remember a ticking noise after turning the key on and before engaging the starter. Lately, there is no ticking noise, but I can hear a slight sound like a fuel pump running. All the normal lights come on and the tractor starts on the first bump of the starter. Glow plug light says they are operating normally.
Should I look into this further?
2,583
As for hearing the fuel pump "pumping" - describe the sound ....ticking is very normal, air in the line DOES change the sound it makes. BTDT
6,639
It doesn't sound like you have an issue.;)
Tractor on! :)
If it quits starting or running then you have an issue. :oops:
Then check back in!
