Is any one familier with the structure of the right angle hydraulic fittings used on the smaller and perhaps older compact tractors. One of the welded in fittings on my LA211 front loader is leaking where the tube welded into the cylinder enters the right angle cube.
Does this cube come apart?
Are there rings or gaskets in there that can be replaced?
Does the allen screw plug come out?
Is the whole fitting pressed together and not repairable?
Welding in a new fitting is possible but requires disassembly of the whole cylinder before and after. Starts to approach the cost of a new one.
Thanks for your help.
Rich
Rich
