I don't have an answer, but will be watching for the results, since I have the same machineDipper cylinder won’t retract
The cylinder will extend even witj a "massive" leak. Disconnect the hose and use a gauge to test the pressure going to the cylinder.Should have added that all operations work except for the dipper cylinder extension. The valve moves freely, and cylinder can be extended by dragging with valve opened. Can’t decide whether it’s a valve problem or massive one way cylinder leak.
Note that this not my L48 but my former employer’s M59 with the Bt1200 hoe.
