L3650
stepper000
L3650
May 5, 2023
96basscat
Hello, I have a 1994 L3650. It's time to do a service for the first time since I've owned tractor. When I called about filters they needed to know if it's a DT, GST, or MT. Im not sure which it is. It has the dual stage clutch and shuttle shift. Hear selectin on right and handle on left to go forward or back. Could someone maybe tell me which suffix mine would be. I'm trying to save myself an extra trip into town to g
stepper000
L3650
May 5, 2023
96basscat
If you're just replacing the fluids I don't think it matters. If it was an HST there would be an additional filter for that. Two wheel versus four wheel drive may make a difference. For a little info you can check out https://www.tractordata.com/farm-tractors/001/3/0/1304-kubota-l3650.html
Yes sir, I looked there as well. I'm just gonna have to get the numbers off filters. According to the parts man, each one takes a different oil filter, but the fuel filters are the same
Bmyers
May 27, 2019
3,569
4,718
Southern Illinois
My limited knowledge is the L3650 came in models, GST (Glide Shift) or the MST (Mechanical Shift). I believe the MST has 4 gears.
The GST will have 8 gears and look something like this
Hopefully someone else can come along and confirm or correct anything I have wrong/right.
CiscoRanger
L4150DT / BF900
Oct 3, 2022
258
133
On mine it is part of the serial #. Have you checked that? Or will the dealer look up your serial # and tell you what it is?
rbargeron
Jul 6, 2015
1,183
260
western ma
Hello, I have a 1994 L3650....... Gear selectinon right and handle on left to go forward or back.....
Its a MT - manual transmission with shuttle lever on left. Its not GST (glide shift trans)
A few of the L3650's had the 'wet clutch', meaning the Ever Clutch. There would be EC decals on the hood, and reversing would not require the clutch pedal.
If it has front wheel drive it's a DT (dual traction). Hope this helps.
