Hi Friends
I am new to tractor world and got myself m4500DT with a 1810 Loader and a RES125 Rototiller for a 8.5K Tag, given all the prices of used tractors i thought that
was quite some deal untill i realized that the blowby tube has a significant blowby, i see white smoke which is consistent and it doesnt stop as the tractor warms up. Glow plugs maybe weak so it starts tough in cold weather but once it starts and warms up starting again is not problem it starts right up, loader works good and tractor doesnt seem to bog down under load. I bought all the oil changes and filters to be able to start afresh including all hydraulic and gear box oils for tractor and tiller and hyrdaulics for tractor and loader. Now i am not sure if this is worth holding onto,My FIL who is a farmer in Michigan suggested even if its a rebuild job it would cost somewhere around 5K which would still make a 55HP tractor pretty reasonable at 13.5K with lots of life ahead of it. I am very handy and looking at workshop manual i could probably open it up and try to cheap out on Aliexpress / Ebay Rebuild kits but am i underestimating the work as the engine block is huge in this(its by no means a small tractor). I have a mechanic coming soon to inspect as he thinks it might be injectors issue before i think its a piston rings issue, I am not sure. Should i go ahead and do 15W40 Oil change + all Filters + all Hyradulics and maybe glow plugs and injectors and expect the best. Or expect this definitely is a rebuild job and i am wasting money on early oil changes.
I also tried searching for reman engines S2600A but there seems to be none and i don't know how much do they go for?
With this forums's expertise i want to open up and understand all viewpoints and then take a decision. Kindly let me know what do you all think ?
