B7100 throw out bearing fork
blfrms
b7100
Nov 11, 2012
placerville, ca
OK, I have B7100 trying to replace clutch, etc. How do you remove the throw out bearing fork from clutch bell housing? I have engine out, grease nipple removed, internal return spring disconnected.
Thanks,
nathaniel
B7100 Kabota
Apr 29, 2023
Carguy08
Hey did you ever find out how to get the throw out bearing fork out?
Ik tgis is 3 years later you probably won't see this but i need to know
Thanks Nathaniel
6,382
Thanks Nathaniel
Remove the bolt and washer at the top of the fork and pull the clutch rod out.
Be mindful of the direction of the fork, putting it on backwards will make it in op!
