Battery for BX2350
robin c
UK
Struggling to get t he right battery for my BX2350. Anyone know the right part number. Thanks.
5,395
According to Messicks its group size 24F (E.G. Deka 524MF) Duracell 24F is $130 and in stock at my local Sams club.
2,839
The 26R works well - the highest CCA you can buy.
These are about $75 in US - not sure what you will pay in UK
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
You don't need the "right" battery. You need one that fits the space and has enough CCA to do the job and has the correct terminal configuration. Take some measurements of the battery location and note how the positive and negative terminals are oriented. Don't overlook terminal height in your measurements. From there go to battery size charts.
Wull
Tractor
Mar 21, 2023
74
14
Scotland
pretty much this, measure it up and make a note of the CCA etc, when you have a look at replacements they will have the dimensions and what the CCA is etc.
6,933
Yep, all good advice. Assume you can reference 24F or 26R in the UK?
Per Dan, Messicks lists 24F, Kubota parts list shows 26R here in USA....that's assuming a UK BX2350 is same as USA BX2350....but betting it is. My BX2360, just a little newer, also takes a 26R.
I replaced mine last year from an auto parts store. Had no inclination to get the "correct" Kubota part #. I bought a "good" one at $150 USD or so. Prices do vary by battery quality, whether real or perceived.
Good luck!
