BX tractor bracket stopper
imnukensc
BX2380
Sep 10, 2015
688
590
Midlands of SC
I'm not quite sure why this is a question, but it keeps the top link in a stowed, stable position instead of letting it flop around when it is not in use on the 3 pt..
PaulR
Aug 3, 2020
579
459
Hadley, MA
There's a notch on the side of the bracket that you hook on the pin/bolt there so the shaft stays erect whle you work on whatever it is you're doing.
4,905
On my big tractors, the top link comes OFF the tractor and STAYS with it's implement. Since al my implements are 'set and forget' , it's a HUGE timesaver.
BX'r
BX2370
Jun 13, 2020
78
17
ipsc
Ok, that explains it.
The top link on my tractor is always in use, when I put on a larger top link the bracket was left off because it no longer fit.
Thanks for the replies.
