Overheated, now won't start.
Love my BX24
BX24 TBL, RCK54-23BX mower deck, BX2750 & BX2751 snow blower
Nov 19, 2022
14
Trent Hills, Ontario, Canada
My BX24 overheated while using the MMM to the point that the reservoir was boiling! Next day the tractor was totally dead. The coolant reservoir was empty, so refilled with distilled water and some coolant. I also plugged in the battery 30 minutes. Still nothing. Have I 'killed' my tractor? What should I have a mechanic look at? Thanks.
3,049
Totally dead as in no dash lights or just won’t crank engine?
Possibly cracked head or blown head gasket.
Also need to diagnose why it overheated. Was radiator clogged on the outside, water pump failure or what?
How long was it run hot?
3,646
2,064
Did you remove the radiator cap and check the coolant level in it also?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,142
1,119
E.
what does totally dead mean?
when you try to start do you hear any noises like clicking of buzzing
are you getting any electrical to the lights or dash
does the tractor engine turn over (crank) when you try to start
is the engine seized
is there water in the oil
is there oil in the water
3,051
There needs to be more to this story - answer the questions everyone has posted and be very specific on what you have looked at and what was the history on this tractor.
6,275
re: The coolant reservoir was empty, so refilled with distilled water and some coolant.
Should have popped rad cap, added coolant there first THEN add to overflow tank 1/2way bettwen happy and sad.
Love my BX24
Nov 19, 2022
14
Totally dead. No response when I turn the key. It probably overheated because the grill (under the steering wheel) got covered is long, dead grass. I have no way of diagnosing on my own and the nearest dealer is 40 minute drive away.
radas
Mar 21, 2022
719
834
Does the starter solenoid engage when you turn the key?
Does the crank pulley turn by hand? (With a socket/ratchet)
What does the oil look like?
What does the coolant look like?
3,049
Okay so we will just start with the basics. Hopefully you have a multimeter or a 12v test light. You can get either one at the hardware store or automotive supply. I recommend the multimeter and a simple one if you’re not that familiar with them. You will just need to measure 12volt DC volt.
Start at the battery and take it to the automotive supply and have it load tested if you have to go buy the meter or test light. If you have the meter then test the voltage at the posts (not the terminals). You should have something about 12 to 13 volts. If not then charge the battery or replace it if it’s older.
Then check the fuses and in particular make sure the larger fuses that protect the whole wiring and are probably not in the fuse box but closer to the battery. Older tractors had fusible links and not fuses for that purpose.
Then clean the battery cables at both ends.
Then check that the fan and alternator belts are still on and tightened properly.
Then tell us what you found and what the tractor is doing afte these steps.
lmichael
Kubota G2160
Apr 23, 2021
845
439
Rockford IL area
I gotta wonder why would someone keep running a severely overheated machine to the point of destruction then wonder what happened?
6,275
same reason some pilots kill their passengers.... 'gotta get home at al costs' mentality ( watch MAYDAY a few times...)
if rad's full(see it at the top...) then losing the overflow isn't a real big problem.
totally dead...electrically, made 'slow blow' fuse is blown or maybe bad battery connections ?
Really need the BX24 wiring diagram to properly diagnose. Maybe free WSM at Kubotabooks ?
10,945
You'll need a good mechanic to diagnose what has happened.
4,184
Pilots don’t “kill their passengers”. They sit up-front where they are first to arrive at the scene of the accident. The passengers stoopidly follow them.
“….What should I have a mechanic look at? Thanks.”
Don’t “have him look at” anything. Let him make his own diagnosis if he’s a real mechanic. Telling him what to do can influence/steer him away from his own instincts/knowledge.
Why do I suspect a troll…
7,611
Not a troll, Geo, just a poorly worded question. He bought a used tractor and has other post about some implements and tires. Be aware some folks are not a wise and had the life experience as you. ;)
