Tractor for 3.5 acres
landstuhltaylor
OH
Need to bounce my first tractor purchase off the hive mind. We are building a house on 3.5 acres of former farmland in central Ohio, so we have a grand total of 2 feet of elevation change. I'd like to get a B2601 in my ideal case but I think logically a 2380 would be fine.
As former farmland the lot is entirely weeds now and will need to be converted to lawn. I imagine this is what will require a good amount of PTO usage in order to prep the lot, but after things are settled that need goes away. The west 1/3 or so of the lot will also need a lot of filling/grading to eliminate pooling water in low areas. It's a breeding ground for ticks at the moment and we'd like to make it all usable. Other than that most of the usage will be mowing and tree/bush/driveway maintenance.
One of the things that makes me lean towards the B2601 is dealing with pallets in the pole barn and hopefully being to store things more easily up high. This isn't a common usage, but just seeing it as something that would be useful. Also being able to move around some heavy items like the 700lb tire changer if I have to etc. I could struggle around without it, but it'd be nice to have. And maybe pushing a 28ft enclosed around the entirely flat and paved parking pad? Not sure that will work in either case.
The biggest issue is just pricing. A 100hr BX2380 with mower and loader seems to be about 16-18k locally which is doable in cash. B series tractors are harder to find and new is more than we would like to spend if possible. That definitely has some "meat pain" as my other half would say (Hong Kong saying for eating too much).
Thoughts on if I should try to make a B series work or settle on a BX?
Rdrcr
Vendor Member
May 7, 2021
769
970
WA
The B2601 sounds like it would be a better fit, especially if you’re planning to use the loader to lift pallets and heavy equipment.
Have you considered taking advantage of the special finance options if purchased new?
I financed both my B2601 and L2501 through Kubota at 0% financing and paid off each loan off in 12 months.
Mike
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,933
2,332
Western MT
The B2601 is still a pretty small tractor. The BX is tiny with very little lift capability. You need to figure out how high you want to lift and how much weight.
Watch some of the YouTube comparison videos by Messicks or Good Works Tractors. Then, go to the dealer to see them in person.
landstuhltaylor
OH
Mike
Is the KTAC insurance required if doing that? If so it seems like that would eat up the savings mostly.
As to the other, yes I have watched a lot of YouTube on them both which is why I'm leaning towards the B. Stopped by to see them in person today, but the dealer was closed and it was raining hard so I didn't get a chance to look closely. Local dealer has 3-4 BX tractors outside and one B so at least there is some inventory.
I also thought about the B2401 and while I've driven some *unintentionally* non-synchro boxes before, it sounds like that's not the way to go for mowing.
Trustable
l2501HST
Jul 5, 2022
397
411
If you don’t do ktac insurance they just need proof you have home insurance basically. You may have to call your agent and let them know but I’m pretty sure that’s it.
6,271
random thoughts...
basement hole dirt can be dumped in the west 3rd as fill..
post 'wanted fill - free drop off' ads, you'll get more than you need.make a temporary 2nd access road if necessary
buy the B2601 WITHOUT the mower deck. 'building a house' means you won't have 'lawn' for awhile. make friends with neighbour with bushog to cut down the 3 acres 1-2-3 times, when needed.
get SSQA on the loader, allows FAST changing of bucket to forks and back
whatever 'house lawn' you have can be cut with a cheap rider
hire a guy with dozer to level out the land. He can easily do it in a day,while you'd spend a MONTH. Up here can get grading done for free when guys drop triaxle loads of free fill.
there's a 1,001 things that NEED to be done when building a house, the priority are HER things and you sittin on a tractor,in the western 3rd ,all day ,'playing' ain't one of them !
GrumpyFarmer
5,164
Hi Neighbor. I started with a BX, and ended up with a B and MX (for now 😉). In my case I really would have been better probably with a small L, but I had a space constraint and needed a MMM. If you can live with a 3pt finish mower instead of a MMM, then you might expand your search to other models and maybe not let machine size be the constraint. You may be able to find larger machines used for less than the BX or B. IMO when it comes to lifting think about the weight of what you think you might want to lift…then Check what the loader specs say. BX will do a lot but they don’t lift much…if you don’t need much to be lifted then the BX or B is sized just fine. Another thing to think about is are there other attachments you want to use and make sure tractor is set up for them (ie. QA would be helpful if changing from a bucket to forks or a grapple and also if thinking about a grapple need a third function…but just for the use of forks QA is very helpful. ☕
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
I run my B2601 on 4.5 acres in NH, long gravel driveway, tree cleanup etc. and general rural residential use. It is large enough to handle some of the heavier tasks with ease and small enough to fit around the property and not require a lot of space to maneuver etc.
soloz2
85
80
WNY
From what you said, a B2601 sounds like a better option. I just got mine 2 weeks ago and love it! I've used the pallet forks more than I ever anticipated I would. I used to have to load and unload my truck by hand, but I've been able to easily unload bricks, dirt, and a small shed with my B2601.
I looked at smaller and or older used models I could have spent cash on, but decided to finance at 0% anew model with warranty and full dealer support. I decided to get KTAC insurance, but could have added to my homeowners policy probably for less $ and less coverage. When financing, you just have to show proof of coverage, you aren't locked in anywhere.
6,271
had I known my neighbour was going to buy a B2601, I'd have bought one as well..While the BX23s has done nearly everything I wanted.... having free use of a BH, BB 300' away would have saved a lot of coins...and STORAGE space....
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
My wife has some good advice. Same advice she had for the RV and tractor:
"Figure out what size we need. Then go one size up."
Coreymacc
Bx 2380
Oct 12, 2022
22
17
Onoway,Alberta
I have a BX2380 with forks and i can lift about 750lbs, i did the B expanded pump pressure check and added a few shims which helped. 700 pounds on the 2380 will be pushing it, but if you don't need to lift it very high it probably will work. I can lift pallets off my pickup but they are only about 200 to 300 pounds. Higher you lift the less weight you can lift. For my application its fine but its definitely not a forklift its a tractor with forks
Corey
3,043
Look at a flail mower for the rear. You can get one with heavier blades for now and swap out to a more finish mower cut when you get it under control if you’re not happy with the cut of the heavier blades.
They are smaller and somewhat safer than a rotary cutter since they won’t throw objects out.
You might think about buying larger use tractor now and then moving down in size later. Try to stay with the same class of 3 point hitch so any implements you have can work with both tractors.
The older purely mechanical tractors are easier to repair but you probably want to get away from gear drive into hydrostatic transmission.
7,603
Jay..... aren't you presuming your neighbor is willing to do that? I had a brother-in-law who's philosophy was "you buy it, I'll borrow it". He's no longer around me! ;) ;)
RBsingl
Jul 1, 2022
488
573
Central IL
Figure out exactly what initial ground work will be one time only and see how those requirements differ from what will be ongoing use. You might find it is cheaper and easier to hire a landscaping/excavating/etc. ground maintenance firm to do a one time ground prep. They will have the proper equipment along with the expertise and experience.
If you do that, you can laser focus on the proper tractor and implements for what you will be doing for the next few decades on your new place.
Rodger
landstuhltaylor
OH
Some good advice so far I'll have to think about.
For the lifting, I'd like to basically be able to lift 500lbs onto a shelf with the pallet or unload from a truck/trailer. Anything over that weight would just be moving it around on the floor. I guess the BX might be able to handle that too if I'm careful with fork weight.
PaulL
B2601, MX5200.
Jul 17, 2017
2,790
1,787
NZ
You don't seem to have any tasks that a B2601 wouldn't do.
I had a BX and moved to a B. The B has more lift on the front, but more importantly a lot more lift on the 3ph. It's much more of a real tractor than the BX is, the BX is limited in a lot of ways by being very low with small tires.
In my experience with weeded areas, you can just mow them (slowly) with the MMM, so long as they aren't too woody. Once mowed once, each time after that gets faster. And anything you mow regularly eventually turns into lawn, even if you do nothing else. If you get a sprayer and spray a selective herbicide it'll turn into better lawn.
If you get fill dropped off, the B2601 will move it around, bit by bit. It won't be fast, but if you do it in spare time you'll get there eventually.
A b2601 doesn't lift a lot on the loader, particularly with SSQA. It's more than a BX, but it's not going to lift heavy things up high. Perhaps understand the weight of what you want to lift before deciding, that's the one chore you list that a B2601 may not do.
Ultimately, it's worth stretching to the B2601. It's significantly more tractor for not a lot more money. Or alternatively wait till a second hand one comes up, which it will eventually. If you have a B2601 in mind, then you'll always be disappointed you got a BX.
PaulL
B2601, MX5200.
Jul 17, 2017
2,790
1,787
NZ
Oh I've got plenty of worn out old brake rotors laying around for that. Shouldn't be much of a problem with a ballast box or something.
Yup. Ballast boxes are cheap. Mine is full of paving stone offcuts. Sand also works.
