I recently bought an old 5' Sidewinder rotary cutter that has no stump jumper pan. The blade carrier itself is fine and is about 21" long x 4" wide x 1" thick. Due to age I can't find a replacement pan that fits much tighter than one that is a total of 30" in diameter. This is clearly about 4"-5" longer on each side of the blade carrier length. I don't think this will be an issue provided I can center the two pieces together then weld the pan to the carrier. The blades themselves have a drop to them so it isn't like the whole blade will be scraping along the pan.
Just wanted to ask if there is something I'm not thinking of that would be a big issue?
