Counter weight vice
Steamer Pete
LX2610
Mar 29, 2021
47
41
Holland, MI
Found a decent vice at an estate sale for $5. Cleaned it up & painted it. Made a mounting pad, and welded it to the counter weight for my LX2610. Gonna be handy when sharpening a chain saw in the field, and other times a vice will be handy outside of the shop.
The counterweight was described a couple years ago here on this forum. Retired electrical panel, TCS draw bar, 2" receiver hitch socket, a little cutting & welding. Filled with concrete from a hole cut into the bottom. Calculates out to about 550 lbs, and works nice on my tractor.
Enjoy.......
2,817
Nice find Pete!
If you want to double your money, I'll give you ten for it?
Also, nice job thinking outside the box for that counter weight. (y)
rotaryjohn
BX2380, FEL, LPBoxBlade, Piranha Tooth Bar
May 6, 2018
14
Ila, GA
Nice find. I would mount the vice to 2 inch bar stock and use the receiver to hold it. You can then use the vice on the back of your truck are any thing that has a 2 inch receiver.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
411
199
Randolph county N.C.
Great idea! I saw a welding truck set up with a 3 jaw chuck from a lathe and he also had a large vise. It was really well thought out.
