I have a m7040 2011 model. The 3ph works fine when you are raising but when you have a load it will not come down, i have forks that go on the back that are about 8 feet long. Two men can stand on them and i can pick them up fine. When i try to lower it will not come down. When they jump off and release the down pressure the forks come to the ground.".......".......,.,.,.,.,,..,,,,..,".......?
Ok i figured it out. After i started my forks needed raising in the back end, so i dropped the top top link from the top position to the bottom hole. Seemed to work fine for a while, and it was until i got to unlevel ground. Anyway i put my bushhog back on and raised the top link up to the middle hole and surprise. Its working. I guess it was getting put in a bind. Thanks for advice, seems to be working fine.
