L3830 Turns over but won't start
PBjr
L3830
May 16, 2015
WOLCOTT
was running fine, after a short time sitting off she would turn over but wouldn't start. Cleaned fuel filter per manual but no luck.
5,236
1,018
Advise cab or no, type of transmission as wiring diagrams are different.
Check for blown fuse...... 5 amp possibly.
Do the check for the stop solenoid connector voltage and the stop solenoid internal coils resistances
The solenoid has two internal coils. A strong one to pull the solenoid open and a second weaker one which holds the open solenoid in position so the engine can run. If you have problems in the pull in side of things the engine wont start.
There is a relay controlling the stop solenoid so depending upon the previously suggested tests it may be the next thing to check
PBjr
L3830
May 16, 2015
WOLCOTT
No cab, all 5A fuses check good, will check voltage at 2P connector, Thanks
