jyoutz
Just buy a box blade, make a box on top and add additional weight. Then you will have something useful out back, not just weight.FWIW I bought a JD "Green" ballast box at a swap meet last fall, and even though it was a "good deal" it will not fit onto the BX23S with or without a quick hitch. I have come to the conclusion that the only way that I will get a ballast box that will work both with and without a quick hitch is to design one myself and then weld up the parts. I have also considered cutting the sides of the Kubota ballast box off and then welding in a new piece of steel to make it into a straight-sided ballast box. I have some great ideas but am lacking both the desire and energy to put them into play. There is a local shop that builds snow pushers and I have talked to them about building ballast boxes that are specifically designed for the BX80 series tractors, but I don't know if there is enough demand for them to do a production run. I guess it will all depend on costs and return on the investment.
