Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
What is that a black puddle??? And why is it on the floor where my tractor was just parked???
Here is what happened this morning. I needed to dig a ditch for a power line.
I checked all of the fluid levels. Then I started her up to warm up a bit as it was around 25°F this morning. After a few minutes I opened up the Man Cave and pulled her out. as I got off and turned around. I had a near heart attack
I saw a puddle (about 1/2 quart) of engine oil at the same spot as where my BX24 was just parked and a trail of oil to where it is now parked. After I was able to breathe again I started the process of finding out where it was coming from. Opened the hood and could not find anything. Took off the grill cover and engine shroud. After feeling around I found a wet spot (mind out of the gutter). It was under the oil filter. I was able to get 1/4 turn out of it (by hand). Leak stopped
Has anyone had the oil filter come loose??? What is the normal oil filter re-torque service interval???
