Before it happens
2,561
Have not had a instance where they come unlatched but figured I’d addressed the issue before it happens
Would a bungie have worked? Chain def aint going anywhere!
Siesta Sundance
Oct 23, 2022
1,560
1,968
youtube.com
Do this as well, add second nut on top of spring, take out a little bit slop. Those pins move when using a grapple or gravel bucket work. You can still use the QA arms the same as before, once locked into place, the added nut just takes up that void above the spring.
