BetterThanAShovel
B2650, BH77, SG0660 grapple, pallet forks, Bobcat 60" box blade
I have another thread going about putting rear remotes on my B2650. I have purchased the P40G-2A1 from summit and I'm slowly putting together the list of fittings and couplers I'll need to get it plumbed in. Some of the decision making is going to be based on where it gets mounted on the tractor. I have two locations I'm considering and I'd love some feedback or suggestions based on that.
I have a backhoe, and my seat rotates to face backwards when using it, so any location would have to take that into account. Pictures are with seat facing forwards and then facing backwards. I'll only ever need to actuate the handles while the seat is facing forwards, I took the seat backwards pics just to show clearance when using the backhoe.
1) Under the seat, mounted on the metal the seat is mounted on
Pictured here, the handles are facing backwards as is the seat. I rotated the seat forward and backwards and even with fittings attached I do not think it will be in the way, although routing hoses and such may be a challenge in the relatively tight space. There's little chance of hitting the handles accidentally when getting into and out of the seat.
An alternative there is same location, but with the valve handles facing forwards. I can slip my hand between the seat and the right fender to actuate the valves, and it would make routing the hydraulic lines a little easier, probably.
With this setup, the 4 connections for the rear remotes will have to be brought out either to a bracket holding the quick disconnect fittings, or to 4 relatively short hoses holding the disconnects.
2. Mounted on the right ROP.
The valve handles are a lot easier to reach here as I'm usually turning my head around to the right anyway to see what the box blade is doing. Routing lines would probably be easier, as it's not in a confined space. It is still well clear of the seat, whether forwards or backwards or rotating.
This position would have a definite advantage if I could mount the 4 female quick disconnects directly on the valve body, and would save quite a bit of money doing so. But what I don't know is if there is enough room when they're bunched together like that to be able to get my fingers around the fitting to cause the disconnect. That seems like it would be pretty tight.
I appreciate any suggestions or observations.
