B 7100 tractor weights
farmer vern
m 6060 / bx 2680 / b7100
Mar 19, 2023
wauconda
i will be doing my own fertlizing this year with a pto driven 3 point ferlizer hooper 400 lbs capacity. I am in a urban area and cant seem to find the proper weights that will easily install on that little front bumper. i saw one on amazon but it was 194 dollars! i do have a tractor supply near by thanks in advance for any help
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
3 of the standard L series weights fit. They are 55-65lbs ea. Weight is pricy, expect at least >$1per lb. Condition does not really matter either since your only talking paint…
2,889
Something else to consider - making weights!
Even if you had to make a "wood" form - that will bolt into the front mounting bracket, you could make this form is such a way (yes - very low budget) that it will hold sand, gravel - or even concrete.
The first two can be removed easily - even if you added 80# on the front - that will make a difference on the rear.
I made a metal "box" on two of mine - with 5/16" chains in them - even that little bit made a difference!
5,852
Did the same for many years using a B7200. Let me suggest you will only want 200-300 pounds of material in that hopper.
Shadetree605
kubota b2100
May 1, 2022
231
117
north little rock, ar
i took the cheap way out, i made a bracket out of angle iron, drilled holes in it to bolt it to the front of my b2100, dropped an old time 12 volt lead battery in it, strapped the battery down with a ratchet strap. easy to remove and bolt back on. so far its helped out alot on the front end.
3,242
I did this:
2,438
Go to your local Kubota dealer and get them there. Usually they will have them in stock so you don’t have to wait or pay for shipping.
I think they will have a few sizes (weights) and only one size will work for the tractor so be sure you ask about that.
