I decided to make a video showing how to test the starter and rule that out, at least you’ll know for sure if that’s what’s at fault or not. I hope you understand my Scottish accent.
I’ll write again what tests to do which helps eliminate the starter.
The first test I want you to do is to test whether power is getting to the starter when you turn the key to start. Now to do this you have to have the tractor configured for starting, so if there is safety switches etc have them all set so it would normally allow the tractor to start. If you don’t do this no power will ever get to the starter.
Remove the switched feed to the starter and connect either a test lamp like I have in the video or use a multimeter. If you get power here this means your problem is more than likely the starter, everything before this point is fine.
Next test is to apply voltage directly to the starter motor. You use a jump lead from the constant 12v feed pole on the starter to the switched feed connector on the starter, you can do this with the ignition off, if the starter cranks the engine then you know the starter is good. If it doesn’t crank the engine then the starter is faulty. If you do this test with the ignition on the tractor might start like it does in the video, I did it both ways just to show, I had to preheat the combustion chamber before showing this.
Like I previously said this test is absolutely fine to do and is perfectly safe, you will not damage anything on the tractor.
