L245 Misfire
b350
10
Mojave
Hello all. I have a L245DT that has a misfire on the middle cylinder. Its gravity feed to the injection pump and I have eliminated fuel delivery as a problem. When I crack the lines at the injectors I get fuel from #1 and #3 but massive amount of air from #2. The air never bleeds out no matter how long the line is open. Line to #2 does not leak and the line holds a vacuum. My question is can an injection pump put air into line? Also the pump with all lines off only spurts fuel about 2 to 3 inches out of the pump. Is this normal? the amount of looks to be consistent for all three outlets. I have experience with gas engines but none with diesels so I would be grateful for any help.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
Check to be Sure the delivery valve on #2 is tight. This is the part that the injection line attaches to on top of the pump. It take a 19 mm wrench. If it lose that cylinder will misfire. The center one is hard to check. You can remove the clamps holding the injector lines together. Remove the injector line from number two injector. Then you can slide a box in 19 mm wrench Over The Line down to the delivery valve to be sure it's tight. Good luck.
b350
10
Mojave
Thanks. The center one did come loose when first took the line off but I disassembled it more so that I could get it tightened back up.
11,208
Did you put all the parts back into the pump correctly?
If with all the lines off it's putting out fuel out of all pump ports at the same heights then the pump sounds fine.
A damaged injector can cause it do odd things.
b350
10
Mojave
I didn't take the pump apart I just disassembled the lines so I could retighten the delivery valve that loosened when I was taking the line off. I took the injector apart and cleaned it but didn't find anything obviously wrong. It made no difference in the amount of air coming out at the injector when the line is cracked open. Open to all suggestions, thanks.
11,208
If your getting air pumped out of the injection pump, that is a first for me, never seen that.
So you getting no fuel out, or just bubbly fuel?
b350
10
Mojave
"a damaged injector can cause it to do odd things" You're exactly correct. I took the #2 injector apart again and some dummy (me) put the pushrod in upside down. Reassembled it correctly and the system bled out fine and ran good for about 10 to 15 minutes at around 900 rpm. Suddenly, massive knock and misfiring again but this time it's #1. A lot of air that won't bleed out. This one is assembled correctly so I think I'm going to throw a set of injectors at it to see what happens. Original problem was random misfire/ loss of power.
b350
10
Mojave
Okay, update. Replaced the injectors ( oregon fuel injection) and I still have a misfire. The tractor starts easily and idles fine but between 1200 and 1800 rpm there is a miss. It goes away above that range and works ok. Is there anything other than the injection pump that could cause this? I should mention that the compression is low at 350-360 but above the minimum spec of 327. Doesn't sound like a compression issue but I just thought I would put that out there.
11,208
Have you adjusted the valves?
b350
10
Mojave
The only adjustment I made there was to back off on the compression release adjusters to make sure they weren't interfering with the valves when hot. Didn't think valve adjustment could be an issue but I'll try it if you think it's possible. Thanks.
b350
10
Mojave
Adjusted the valves (all loose) and no change. Still misfires at 1200 to 1800 Rpm.
11,208
Do a compression test, that will tell you which route you'll need to look next.
utterchaos
L245DT FEL l39 TLB
Mar 17, 2023
24
9
Chenango, NY
Long time reader and learner on the forum…..first time poster .
I have the same machine, I don’t have the problem but curious If you resolved this in case I encounter the same.
