Kubota L35 TLB - Gear Shift Change Mechanism
3,710
2,283
Nice work! What's that thing sticking out of the hood? My hood has a blanked off hole there. I've wondered what it's there for.
10,622
He put an aftermarket dust separator / pre-air cleaner on it.
10,622
It was for a pre cleaner but I can't find any reference to an option number for it.
I could see it being useful if you were working really dusty material.
Nicksacco
Sep 15, 2021
763
501
Bahama, NC
Thanks guys.
The blanked hole on the top of the bonnet doesn't seem to have a reference anywhere in Kubota docs.
I assumed it was for a pre-filter, so that's what I installed. I used a stainless exhaust pipe adapter to get from the OEM input hose to the pre-filter. You can see it sticking out of the bonnet.
The L35 has a 4-post ROPS that's very stout.
I've repainted the front posts and upper support system for the roof.
The rear posts were nearly rusted into the tractor, so after getting them out, I had them blasted and they are awaiting paint. I need to work on the tractor channels where the rear posts are inserted to clean up the rust and such. Then paint the roof itself.
In addition to replacing some pins and bushings, I also am working on the backhoe release mechanism so I can remove the backhoe.
Again rust, has made this difficult. Once I get the backhoe squared away, access to the rear of the tractor will be much easier.
Lots of rust and cleanup on this machine. I'm glad I took lots of pictures because sometimes I don't believe the mess I had. I've powder coated every linkage and part I could - it's been quite a journey!
These are the parts to install a pre-filter from ebay. Just turn the OEM hose around and line it up with the hole in the bonnet. I used radiator-type clamps to secure it all.
5,188
Thanks guys.
Your work looks to have been exhausting.....but is truly excellent.
Makes me appreciate my 2006 L48 even more.
Bought (06/2019) with 251 hours, and had lived outside.
Only rust was where specification tag/decal was glued on.
Replaced seat.
Removed, and re-sprayed ROPS top, plus both fenders, then compounded the rest.
Stacy73
L35
Mar 21, 2026
Savannah GA.
Hello everyone,
Just wanted to say thanks to Nicksacco for you post. Your pics and descriptions saved me lots of time with T&E. I bought an L35 in Febuary this year and it wound up having a bad shift mechanism. Problem with it was one of the cable housings was melted and mangled. I didn't take any pics because I didn't think what I tried would work. I used an old Honda 150 clutch cable and cut the housing and cable to cobble togeather something that works perfectly. By the way, Kubota now wants about $1,100 for a new unit.
