Siesta Sundance
Ha. I did go back to house about 130 to let the dogs out, I grabbed peanuts, protein bar and a banana, lunch on the go.Did someone bring you another sandwich sometime during the day?
I bet that Live Oak feels better already. Good Job!
2 today, ribbon snale and garter snake.I bet that Live Oak feels better already. Good Job!
You run across any snakes yet?
My 4 stroke Honda brush cutter has an excellent body harness.Grips of some sort definitely make it easier to cut brush. My Brush cutter came with handle bar handles and I hook the whole unit in a harness, that way the weight is distributed better.
What you are referring to is new, called : "Shrinkflation"This inflation has a depression effect on new grease tubes. I should be able to return 10 used tubes for one new tube of grease.
^^^^^^My 4 stroke Honda brush cutter has an excellent body harness.
A great machine,.... but I am getting too old to use it safely....a trip and fall issue.
I don't use the shoulder strap because I have ran into wasps before, I want to distance myself fast as I can!!^^^^^^
That's really the only issue with being 'Tied/Harnessed' to the brush cutter. A trip or fall can be hazardous.
A few years ago I was cutting some saplings in an area that I Deer hunt, just wanting to thin things out a bit so I could see better. There are a lot vines and other vegetation that make your footing difficult to begin with. Lugging the brush cutter makes it all the worse.
I didn't see a big nest of Paper Wasps on a limb (about head high), so when I got right under it... a bunch of them attacked (can't blame them). So there I am....harnessed to my brush cutter trying to put some distance between me and them....but to no avail, brush cutter was snagging on everything.
My harness has a quick disconnect but its not easily manipulated while swatting (unsuccessfully) with one hand and stumbling through the brush and vines. I finally just had to stop, free myself from the brush cutter and then continue my retreat. Got 13 stings.
Usually wasps don't pursue you very far. Unlike Yellow-jackets and Hornets which aren't happy until they've followed you all the way home. But this bunch was 'dedicated'.
Went back to my truck to lick my wounds for awhile. Then eased back in to retrieve my abandoned cutter, still idling away.
