Creeps, B2620 HYD doesn’t center
RQJ
Kubota B2620
Dec 17, 2020
Maine
I have looked around for answer to this problem but can’t figure it out. Whenever I remove foot from pedal it will continue to creep in that direction. I just removed the damper so pedal would move freely and it does same thing, will try to attach video. Can’t see much underneath that controls the centering of pedal, all linkage moves freely. I guess I can’t attach video. Thank you.
5,066
You need a certain minimum amount of posts before being able to add pictures.
5,308
Can’t attach video. Need to use YouTube and post the link.
You can post pictures after 5 (?) posts.
A few years ago (4-5?) at least a couple OTT members had similar issues with B2650’s. I recall one documented it and the fix well.
Don’t recall if it was an issue with the damper on the linkage, but it wasn’t a major ordeal if my memory serves.
If you use the Search function on OTT for creep, you might find some posts specific to B2650.
PS - - found a couple of them:
Creeping B2650, HST pedal not centering... fix | OrangeTractorTalks - Everything Kubota
B2650 hydro pedal creeps out of neutral | OrangeTractorTalks - Everything Kubota
HST creeping forward | OrangeTractorTalks - Everything Kubota
RQJ
Kubota B2620
Dec 17, 2020
Maine
Thank you, I will take a look at those threads. Posting stuff to other sites and linking them is a little over my head, I don’t use any of them.
5,308
Same here…. I don’t do much YouTube, and sure as shYt don’t know how to do that either.😳
I misread your model number and posted B2650 links. My bad and my apologies. Definitely time to change my bifocals….
Just guessing it could still be something similar to your B2620.
Sorry about the distraction.
RQJ
Kubota B2620
Dec 17, 2020
Maine
No problem, not sure difference between 20 and 50, haven’t had a chance to look yet, thank you
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
135
45
newark valley new york
You may want to check on a reply that North Idaho Wolfman posted back in 2016. He lists the parts that are involved in centering the pedal.
RQJ
Kubota B2620
Dec 17, 2020
Maine
I will try to find that, I took a closer look at it when I put damper back in, linkage all moves free, can’t see any springs, maybe issue inside transmission, hope not
6,452
There is an external spring, if your missing it no wonder it's not staying in neutral.
The WSM will explain how to adjust it.
If it does it randomly forward and reverse the bearing is out.
RQJ
Kubota B2620
Dec 17, 2020
Maine
I just don’t see any external springs connected to the pedal rocker, like I said earlier when I removed the damper to free up the linkage, the linkage just kinda floats in neutral position. Just took a picture, springs for brake but nothing on shift pedal.
2,928
1,388
The spring and linkage that Wolfman highlighted in the picture are inside the frame. You can not see them without laying under the tractor and looking up through the opening.
BAP
Dec 31, 2012
2,763
876
Try tightening nuts number 120 in the diagram that Wolfman posted. It puts tension on spring number 100 which helps with the pedal tension and return to neutral position. I have had to adjust that on my B 2920
RQJ
Kubota B2620
Dec 17, 2020
Maine
will take a look when I go out to garage, hopefully access to it from underneath.
BAP
Dec 31, 2012
2,763
876
Yes, the bolt with the nuts sticks straight down about in the middle of the tractor under the operator platform. Crawl under and you should see it. It is double nutted, so you will need 2 wrenches.
RQJ
Kubota B2620
Dec 17, 2020
Maine
This may be an issue, looks like that adjuster is missing, now to figure out parts needed and how assembled
