Sidekick accessory plug in
Plant 175
Kubota Sidekick
Jun 3, 2021
120
Wisconsin
A few years back I purchased my Sidekick I asked the dealer to hardwire a plug from the battery to the bed so I could plug in things like sprayers and fertilizer spreaders. Well they hardwired a connection from a Boss snowplow and said to get an adapter to scale it down from what it is to what you need. Now I can’t find an adapter and neither can the dealership. Anyone have an idea what I can use ?
EFC9FC50-64CC-46A0-90F6-4A850E2EA5A3.jpeg 10A91EA1-33FB-48CD-B46C-F90B082CB392.jpeg
JamesW
850 Sidekick
Aug 19, 2022
North East Texas
I'd suggest replacing that with a standard SAE quick connector. A good example is the battery connector you get for a Battery Tender charger. Amazon has a zillion SAE quick connector options. Plus you can use it to keep your battery charged.
3,554
2,019
I wired a separate fused disconnect to a power port in the bed controlled by a power relay. That way I can turn off the pump/aux port from a switch on the dash.
johnjk
Apr 13, 2017
1,462
1,272
West Mansfield, OH
For my sprayer, I just use the quick connect from the battery tender and the other end from the sprayer. Northern Tools. It came with multiple pigtails to either hard wire to battery, or use terminal clamps. Cable is fused as well. I have enough slack that the on off switch sets on my leg for east access in use. If your accessory is pulling a lot of power you may want to fuse that connection or run it off a dedicated circuit and size the wire gauge to support your draw. I like the idea to have that 12V access in the rear.
JamesW
850 Sidekick
Aug 19, 2022
North East Texas
Small sprayers and fertilizer spreaders don’t pull much power. They could easily work off the SAE connectors (battery tender connection). It would be easy to put a switch in line and run it to the cab through the back window
