LX2610SU with R14T 15-19.5 tires
robi
9
canada
It is in anticipation of a purchase. I hesitate between 14X17.5 and 15X19.5. Not mentioned in the manual found on the internet. I would like someone with this tractor and these tires to give them to me because I can't find anything on the internet.
Daferris
LX2610
Nov 23, 2021
483
404
Mid-Michigan
I have the 15x19.5 filled with RimGuard on my LX2610HST. I like the R4 better than the R14. Why I work in my woods more than 50% of the time. R4 have thicker tread and sidewalls. Also you can get almost 200 pounds more ballast in the bigger tires.
Thank makes a big difference in traction.
Speaking of traction I seldom need to 4wd even when plowing snow. ( Mid-Michigan).
Ground clearance I have never measured it but would guess 1-2" more than with the smaller tires.
robi
9
canada
Me too, it's for working in wood so I want the highest possible ground clearance and not too wide (less than 56 in.). If I have more than 2 in. but no more than 56" wide, I'll take the 15X19.5
Daferris
LX2610
Nov 23, 2021
483
404
Mid-Michigan
This is the best photo I have of mine showing the tires. I know it's more than 56" outside to outside. Forget for sure but it's probably 59-60"
Also if your getting a grapple look at the EA wicked 55. The serrations really help hold the logs in the grapple..
robi
9
canada
Difficult to estimate from a photo but if it's 59 or 60 in I would take the 14X17.5 tires which gives a width of 54 in.
Daferris
LX2610
Nov 23, 2021
483
404
Mid-Michigan
The 14*17.5 R14's are the same overall width as the R4's the info in the manual is the center to center measurement. I can measure mine later today when I'm out in the barn....
robi
9
canada
Thank you that would be appreciated (exterior width as photo). Can you measure the ground clearance also which should I believe should be 15 to 16 in.
robi
9
canada
I see an overall width of 56 3/4". on your tape measure. Your tires are R4. The R14 should, I believe, have the same width. It is therefore the 15X19.5 that I will take. Thanks Daferris for your help.:) Does anyone with R14s confirm?
S-G-R
LX3310
Jun 17, 2020
1,131
2,290
PEI Canada
I have the tall loaded R14's on my LX3310 and center to center is 42.5" and 58" from the outside.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,406
1,827
Western MT
Higher ground clearance also equals higher center of gravity which isn't a good thing on uneven terrain. You might try wheel spacers, too.
Fwiw, from the reviews I've seen the LX has a higher ground clearance than an L01 which is a lot heavier tractor. Mine can feel tippy with loaded tires, FEL, and rear implement. I wouldn't want to go even higher without going wider with spacers.
robi
9
canada
I want a high ground clearance and a minimum width to circulate more easily in woods and on small 4-wheel trails. I am aware that the center of gravity is higher. Indeed the ground clearance of the Lx2610 is 1.2 in. higher than the L2501 (regular tire)
