L45 front 3rd Function Fuse Blowing Intermittently - HELP!
akgsaab
Kubota L45
Aug 10, 2020
Nevada City, CA
Hi all. I have a 2013 L45 with the factory third function valves on the FEL. The fuse, which enables the press button switch, blows intermittently when the switch is enabled. I have replaced the switch and wiring but it continues to blow without any discernible specific thing that I do that causes it. I am not even sure that it blows when the valve control is in use.
Has anyone experienced this or any ideas on where to start tracing? It is very frustrating, especially when using the 3rd function valve for snow plow angling.
9,273
Sounds like you have a coil that is shorting out.
Replace the fuse with a resettable circuit breaker of the same size, will make it easier to find the part that is failing.
9,273
Great idea. How would I be able to test the coil? Any ideas for me?
Measure the coils with a multimeter on beeper or ohms, one lead to either coil wire and one lead to metal on the valve or the tractor.
You could also measure between the two terminals on the coil, and compare the two coils.
They should be between 10 and 100 ohms.
Look at the coil body for cracks or swollen areas.
akgsaab
Kubota L45
Aug 10, 2020
Nevada City, CA
Thank you. I will investigate further tomorrow. For now both are reading 4.8ohms across the terminal connections.
Any thoughts on that reading?
9,273
That sounds good, but they could still short to ground.
46
88
Ontario
Hi I just put a Kubota third function valve on my B2601, it went good. But when I tested the switch I heard a klick from the 3rd function valve. Upon investigation, Kubota had put a 5 amp fuse in for the accessory wire which is not much good for anything. According to the service manual it can take up to 35amp fuse. After putting a heavier fuse in it works fine. Food for thought.
5,179
Kubota obviously had a LARGE supply of 5A fuses,.... and no other use for them? ;)
3,921
2,568
A 35A fuse to replace a 5A is a great way to locate your bad connections...just follow the smell and look for burnt wires. You might even hear some buzzing initially.
46
88
Ontario
I should have clarified that I put a 10 amp fuse in place of the 5 amp to start with. I will see if it is heavy enough once I get my homemade grapple hooked up. THKS
5,796
both coils read 4.8 ohms. nominal battery voltage is 13.2
current is v/r, 13.2/4.8 = 2.75 amps, so round up to 3 amps
This means the 5 amp fuse is a 'good' choice,7.5 would be the max though.
Coils are 'inductive' loads and can draw 10x their holding current, but only for a brief time. All fuses can withstand this 'inrush' current.
While the manual says that fuse position can have a 35A fuse, you would need 8 gauge wire to power the 'device'. 8 ga wire is 'fat', like on a car alternator. I suspect the 3rd function wires might be 18 gauge, like the E-pto on riding mowers.
Somewhere between the switch and the coil there is a 'grounding' issue though I'd have to see the wiring diagram and some pictures to better diagnose. Though rare it could be the coil where part of the winding is connecting to the plunger,so perhaps remove the coil and inspect very.very carefully.
5,672
Disconnect the coils and operate the switch. If there is a short to ground in the wiring harness the fuse will still blow. If it dors not bloe the probkem is in the valve.
akgsaab
Kubota L45
Aug 10, 2020
Nevada City, CA
I may have found my culprit thanks to all the advice here. I started pulling on parts of the harness and exposed an area that doesn’t have a protective sheathing and runs near a relatively sharp sheet metal a the bottom of the loader stick housing.
When it’s light I will evaluate further. The harness is $110 or I may be able to just repair and heat shrink. 🤞
More to follow!
5,796
hmm.. wht/red wire randomly hits sharp orange steel = POOF !
sounds like you FOUND it !!
while you're 'in the neighbourhood', plug the ends of that connector with yellow wire, to minimize corrosion and THAT failing in the future....
