Trailer mover
mkohnen77
L3302
Mar 2, 2023
Any suggestions for a trailer mover 3 point attachment that works with the qh16? I bought one online but it's short a few inches side to side.
B737
LX3310
Jun 9, 2019
2,022
2,205
If pins are short you could get longer pins?
I use this one from Titan, (CAT I), cheap, has worked well. It is compatible with QH10 when it is dropped straight down into the QH. If you have moved your hook from standard position it may not work, or need some modification.
I have moved my 20' 7,000 pound (1,800 empty) trailer and 22' 15,000 pound trailer (3,500 empty) with no problems the last few years using it. I use the rear bracket more often than the bucket, it's just easier and more stable.
You could also weld a receiver to bucket for quick moves.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
I use Heavy Hitch 3 point weight bracket/ receiver hitch. While I do not have a QH, they say it is compatible. That is the reason I bought it.
4,173
I weld a 2 inch receiver to just about everything.
I welded one to my QH as well, but no pics of it.
Except my forks. (3rd pic) For that I made a "Quick disconnect shoe" that fits over the "port fork" and is held in place with a lynch pin...Then I welded a receiver to that. Lots of ways to skin a cat I guess.
Sporto
B2601-1, FDR1660, RTA1258, BB1560, LR1672, PFL1242, MK Martin Snow Blower
Mar 20, 2021
72
Manitoba Canada
As per the Kubota Canada website the QH16 is supposed to be CAT 1 and its claim to fame is that the pins are also CAT 1, same idea as the Speeco E Hitch. I wish that they had this model when I bought my QH15 :unsure:
9,618
I have this model from King Kutter that I use with a QH10 and QH15. Not sure if it'd work with the QH16 though but maybe worth considering if it will.
beeckstein
Northern California
I got this one to use with my QH16...
Super nice construction, great folks to work with, and made in USA. Yes, more expensive than the Chinese junk, but I'm ok with that.
