BX2680 Wheels/Tires Fully Compatible with BX24?
Harveybravo
BX24 Loader and Backhoe; Ford F-350 diesel dump; Vermeer BC625A; Numerous Stihl
Feb 28, 2023
12
Knoxville, TN
I have an opportunity purchase 2 front and 2 rear wheel/tire combinations. They are off a BX2680. Tire sizes are 26x12-12 and 18x8.50-10. I simply need certainty that this set will mount up on my BX24. Any help is appreciated. Thanks!
4,987
They should fit your tractor based on the tire size. As far as I know, the lug pattern is the same across all the BX tractors. You should check with your local Kubota dealer salesman to get a current price on tires and rims as sold by Kubota "wholegoods" to make sure that the price you are paying is fair as compared to buying new that will come with a warranty. I have seen some used tires & wheels advertised on Craigslist and Facebook marketplace that are higher priced than new ones at the Kubota dealership.
Harveybravo
Feb 28, 2023
12
Knoxville, TN
I've been told before to utilize my local Kubota dealer for tires/rims. There are 3 dealers close to me. Either they gave me incorrect information then ghosted me; or were only willing to quote me all 4 and I only need fronts (and the 4 I was quoted were higher than I see used by a lot); or they simply cannot get them. Maybe supply of rims/tires is low at the moment? Thanks for your help!
2,600
Those will fit for sure - if'n you were placing those on the smaller BX then you will have a front end problem with the rims.
2,600
"The smaller BX?" Educate me please. Thanks!
bx1850-bx1860-bx1870 ...they use a smaller rim and tire set up - same bolt pattern but rims from larger Bx series will bind on the front end - 7.5 rim vs 8.5 rim
hodge
Nov 19, 2010
2,906
453
Love, VA
And the older BX1500.
