I picked up an L3010 HST yesterday with 1100 hours on the clock.  It's been neglected a little and I spent the day tinkering with it.  The Glow plugs don't work (probably the timer, not sure yet), and the shut down solenoid doesn't either.  I started with a look in the fusebox and sure enough, the 15A fuse for it doesn't have power to it.  I pulled the fusebox for a closer look and the terminal that connects to the wire in broken and not making contact with the fuse.   I've tried looking at online parts sources for this terminal but I'm coming up blank.  anyone know of a source for them? If not, I'm sure I find a terminal to fit in there, but I'd certainly like to fix it right if I can.
Next, what is this lever for? I can't figure out what it does.
And lastly, I've got a hydraulic oil leak. This is the forward junction block on the right side of the tractor, right near the filter. This pipe is leaking at both ends. It doesn't look bent or damaged. I cleaned and dried it to make sure that's where the leak is. Are there just o-rings on those pipes?
Any help apppreciated.
Joe
Joe
