Leaf raking tools
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,563
I'm looking for the same answers as the OP. I have a bx-2680 with a 55" grapple, bucket, stump bucket, sod buster plow, 60" center mower. I still have loads of leaves (a couple of acres worth) left over from last fall.
We had raked them into a series of piles. Many of the piles are on a fairly steep grade.
I got some success using the grapple. One advantage of racking them in the fall and letting them sit through the winter is that they have become "lift-able" with the grapple. I can pick up a clump that is about 5 feet high, wet and packed. I pick the pile up and take them over to the compost heap. But I still have a lot of leaves to rake.
I am still looking for a solution for the remainder of the leaves.
I'm my limited experience, the type of leaves can dictate what tool is used. We borrowed a Protero vacuum to try it but it didn't do much for the tiny leaves. We have a ton of Willow Oaks and their slender leaves like to burrow under and in the grass. I had the most success with a backpack blower and rake (for the really matted areas.
Big leaves would be eaten alive by this machine. Just not the little guys.
bird dogger
Feb 24, 2019
1,800
1,772
North Dakota
AgriMetal PTO leaf blower:
One Pass:
Easy to keep up with leaves when you can hook up and go in just a minute or two whenever there's a fresh batch of leaves on the ground.
bird dogger
Feb 24, 2019
1,800
1,772
North Dakota
curious.. what's the semicircle of steel on the blower for ? I went to the website and none there look the same....
The semi circle of steel is a 180° deflector that can be raised to blow straight to the left of the tractor. If lowered it redirects the airflow to the right side of the tractor.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Is there any reason not to use the powered grass catcher? It's not been listed, but I've used a bagging system on my little Ryobi riding mower the last two years to collect leaves, here in New England where we see a lot of leaves, and its done great. I'm just curious, as the tractor I bought came with the GCK60-26BX, and I'm wondering if its an issue to use this for leaves?
someguy9000
44
21
California
it will fill up absurdly fast. You certainly can use that. I would say, it depends on how well the impeller on that handles debris. With me, my "leaves" are sticks and acorns too. I can't mow every week.
The load will be heavy too, so gotta have that front ballast.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Makes sense, I mow at least once a week (would do less if I could, but it grows quite well here) and during leaf season, I pre walk the property and pick up any sticks or other debris that wouldn't be easy to collect. I will report back this fall as to weather or not this was an issue.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
148
59
Central, ME,USA
I went to a cyclone rake for my zero turn. I does work really well, but they are expensive new.
11,092
I guess one real advantage to our rough winters, I've yet to worry about raking up leaves, winter breaks them right down to nothing!
