Paging Dr. Hackenslash.....Paging Dr. Hackenslash.......
4,872
It would take 43 minutes longer, not 1.5 hours and it would take much less fuel. 🧐
That's 43 minutes longer than I can hold it. (now that I'm mid fifty'ish)
I can normally get there without stopping in 4 hours.
So, a head call, (plus a burger) is 1.5 hours'ish...hahaha
4,872
one old skool 'fix' for overheating engine was to turn heater on full fan and hot. It'd drop the engine temperature from 'meltdown' to 'we can get home'.
the HUGE issue with 'overheating' is the automatic tranny literally frying !
another way to prevent overheating on the highway..... remove plow, toss in pickup box.
YEP, I have done the heater trick already.
Tranny is not an issue, It's a 6 speed G56 manual.;)
When I tow the tractor, I do put it in the box, but that's not always practicable.
BAP
Dec 31, 2012
3,110
1,244
Buy a cheap, beater plow truck and leave it at your second property.
MountainMeadows
Jun 6, 2022
219
290
Poconos, PA
I, kind of, get that but where would I place this fan, and how would I regulate it? I can't really think of anywhere to put one that would fit.
I don't currently own a Dodge truck but have owned 2 in the past. From what I remember there is plenty of room between the grill + front of the ac condenser + radiator. I would try to find a used elec. radiator fan + shroud assy. from a front wheel drive vehicle. Then fabricate a mounting fixture for it in front of the ac condenser. You can regulate it with a coolant temp sensor or just hook it up with a toggle switch and keep an eye on your temp gauge.
4,872
I looked yesterday and this might be feasible. I have to take some more detailed measurements, but it might be a better way to go.
The wing is working, but as mentioned previously, the draw backs are becoming more and more of a PITA.
6,205
re: Buy a cheap, beater plow truck
hahahahahahahahahha... good one !!!!!
just WHERE can you find 'a cheap, beater truck ' , let alone a plow truck !!!!
but, since removing the hood isn't an option... upgrade it by installing louvres into it.
Now that's really old skool...still done on Morgans today !
Naturally everyone will want your hood, so you'll make a million selling themas aftermarket upgrades.
BAP
Dec 31, 2012
3,110
1,244
I thought about that, but I use it at home as well.
Leave the cheap beater at your second property and keep your current one for home. What you save in gas from not having to push the plow all the way up and back will pay for it over time.
BAP
Dec 31, 2012
3,110
1,244
You can find cheap beater plow trucks if you open your eyes and keep a lookout. There are lots that get sold that still have life but aren’t road worthy.
trial and error
Feb 16, 2023
394
386
NY
Maybe not a second truck but a second used similar plow may work. You would only need the plow side not the truck side of course that is probably a fools errand who knows just a thought
BManFX4
BX2380, RCK60B, LandPride RTA1250, CountyLine RC5, Titan BX42S Chipper
Apr 14, 2020
32
Loudon, TN
I just want to say Kudos for building that cool, functional wing !! Re-directing airflow at speed is as much art as it is science. I'm impressed Sir !!! :)
I was riding my motorcycle at a fairly quick clip. A large bug splattered itself right at the top edge of the windscreen. I reached up to brush it off and when I had my hand there I noticed a drastic reduction of the air hitting my helmet. Fascinated I spent some time turning my hand, adjusting how high above the windscreen it was, etc. and discovered that very small adjustments made a huge difference in airflow.
Armed with my new knowledge I searched for and found a small, adjustable deflector that I added to the windscreen. It completely changed for the better the comfort level for me when riding at highway speeds - and it really helps with directing rain up and over my helmet as well.
4,872
Thanks for the kind words Bman, and I'm glad it inspired you.
Nice bike btw! (y)
Crash277
BX23S
Jan 17, 2021
844
623
that is a great idea!! i used to have a 1200 bandit that bike was fun to ride. now i have a nomad couch.... i get some good buffeting on my helmet. can you send me a link to that deflector>???
notaz3
90
91
ID
Now you are making me miss my Bandit. I've had one just like that as well as a blue 1250. Wish they still made them.
