Grapple
Code
l3301, fel, lp boxblade, 12" lp auger, lp bush hog, z421 zt, lawnvac leaf vac
Dec 19, 2020
132
Central, Va
Honestly the SGC0654 would probably fit my use as is really just brush cleanup and carrying 4 ft logs to the processing area
The SGC1060 grapple is a heavier duty grapple than the SGC0660, and it weighs about 150 lbs. more. You would be paying more and giving up lift capacity for a stronger unit. Would the stronger unit be of benefit to you - only you can say? I have had my SGC0654 for over two years. It shows no damage, and I have never been wanting in terms of functionality. I use my grapple frequently; it stays mounted on the loader. However if I am planning to rip out some small bushes, I use my bucket with the tooth bar. Some people dig more in the dirt with their grapples, but they are risking their loader and hydraulic system on compact tractors.
Donystoy
Dec 10, 2013
561
214
Binbrook, Ontario
I will also be just using mine for moving brush and smaller limbs. Anything larger is cut and split where it is. Any digging I do with the back hoe. One thing with the Kioti's twin cylinders is that I have the option of converting it to a dual grabber in the future with minimal fabrication.
3,296
Hell I use the grapple more than I will ever use the bucket! Remember if you aint got some bent tines you aint usin it :)
mcmxi
6,205
NW Montana
Ted of Everything Attachments put out a video today showing an even more upgraded Wicked 55 and it looks great. They've added steel between the tines with "teeth" to get a better grip on trees, roots, limbs etc. I'm going to email EA and ask them if they'll sell those pieces as an upgrade kit for those of us interested/able to weld them in ourselves.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
He's a wild man on that 6060! Ted say, "I need a bigger tractor." Hmph... <looks at little B> (-;
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,814
2,824
After watching that, it's official. I operate my tractor like a grandma.
PaulL
2,419
1,348
NZ
I thought I worked my B2601 pretty hard. But it seems I have a fair way to go before I should be concerned.
Donystoy
Dec 10, 2013
561
214
Binbrook, Ontario
Certainly would not loan my tractor to that chap. Would not even consider using a grapple in that fashion. This is why you have appropriate attachments.
