M7040 rear remotes.
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Working on a M7040 and adding a hydraulic rear blade, the tractor has one rear remote and spots for two more levers. Not to suggest that Kubota's parts are not worth the cash but close to 800 for each remote kit is a little steep! Are all M series rear remote valves the same? assuming detent or self centering spools. It looks like a pretty simple block with a 3 bolt attachment and o-rings. I'd like to keep the factory look intact so going with a cross valve would be out.
thanks in advance!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Unless they have made some changes I think they valves are the same aside from function. They must have really had a price increase since I bought mine. My dealer installed extra remotes for $500 each but that was a few yrs ago.
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
A little off topic but related...I would like to see someone with rear remotes on a L3400 post a photo of the hydraulic setup.
fast*st
Jun 26, 2012
172
Northern Mass
Well, most of the dealers I've called list $ 600+ for each remote and $125 for the handles/controls hopefully can find a dealer who will deal but it might be set by Kubota.
MtnViewRanch
894
351
Lakeside Ca.
If you have a kind Kubota dealer, I think that you should be able to get 10-15% off of those list prices. It sure won't hurt to ask. ;)
Oh, since you are getting these for grading purposes, I highly recommend that you get the next 2 with the float function. Many times using the float function will make your finish grading-smoothing come out much nicer.
Skeeter
M4D-061 w/FEL; RTV X1100CWL; JD MX-7 Bushhog; and others
Oct 3, 2012
26
MO
That's a little better than around here. I just bought an MX5100 and they charged me $800 for one rear remote. I shopped two other Dealers and had them price the tractor to my specs and both of them also wanted $800.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
My dealer charged me a whopping $500 for giving me a rear hookup. Essentially it was a couple of long hoses in the FEL return line, with quick disconnects on them. I picked up the pictured valve at Big R for $99, a couple of quick disconnect sets at about $45 ea, and some hose. I could have gone to a dual valve, but I am worried about fitting my backhoe in there.
fast*st
Jun 26, 2012
172
Northern Mass
Picked up a pair of valves 2610 for the M40, found out the bolts for attaching the valve stack to the tractor come with the handle kits! :) All set and ready to rock now.
Big Country
M7040
Mar 4, 2015
Senecaville, Ohio
Don't know if you are still using this site but do you mind if I ask you a few questions about your M7040. I just got one and would like a opinion from a owner that has had theirs for a while?
fast*st
Jun 26, 2012
172
Northern Mass
Most certainly, we (sportsmens club) use ours on the far heavy side of a typical user, sometimes a tank of fuel barely lasts a day.
Ask away. (sorry for the late reply, ott binned the message outside the active thread window)
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,278
179
Coyote Flats,Texas
What do you want to ask? I own a '11 M7040 that has 950 hrs on it's speed/hr meter.So far so good.
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
I have a M7040 also. I had 3 rear remotes put on when I got it . I have found that I get back this money back when I trade with factory equipment on them. It is well spent!!!
fast*st
Jun 26, 2012
172
Northern Mass
Good at least that the remotes also hold value well!
Jamie Stretton
M-7040
Mar 11, 2026
Australia
Hi Everyone
I am in Australia and have a M-7040DH which comes standard with 2 pair of remotes
I am just adding a 3rd pair for a grader blade
M7611 Hydraulic Valve FD KU3C081-90171 is AUD $1,288.00
M7613 3rd Position Valve Lever KU3C001-97101 AUD $286
Kubota don't do their owners any favours with their parts pricing
Cheers from Down Under
