dawrigley
L1501DT, Hayes slasher, grader blade, dirt scoop, carryall and ripping tyne
I've just rebuilt the front drive units of my L1501DT, straighten the tie rod and fitted new tie rod ends etc. etc. All was going well but when I reconnected the drag link and moved the steering wheel to align the drag link tie rod I noticed the front axle moved - a lot! While I didn't measure the movement it appeared to be around 3/4-1" of movement forward and back in line with turning the steering wheel. I've had the tractor for around 6 years but never noticed any movement, but then I was never looking for such a thing - plus I've always been looking where I was going.
Just wondering if anyone might know anything about this? There are grease nipples on the gearbox side of the propeller shaft and the other side of the front diff. It appears as though the diff is designed to slide but I've never come across such a thing before - it freaked me out when I saw the amount it moved.
I only removed the front drive units and the tie rod, meaning I didn't touch anything else and I have no left over bolts or the like but I'm wondering if a previous owner has fiddled and left me with another challenge I need to fix. (I've had a few to deal with.)
