Refueling Simplification
lynnmor
B2601-1
May 3, 2021
1,736
1,538
Red Lion
I will try the new pump and see if it pumps well from the ground.
Mine pumps real slow from ground level, higher is better but don't go so high that it will siphon instead of stopping the flow. I found that the floor board is best and I can lift with both hands making it rather easy.
3,911
Hi Folks,
I know we have a number of threads on this topic and many have sophisticated refueling systems ( someday perhaps ) but many still fill a 5/6 gallon container and pour it in. As I age, the process of hoisting the full can up for a funnel pour has become less attractive. I bought this siphon at Home Depot for <$10. A couple of tips and it works great.
1) Lift the loader forks up a tad and then set a board or two across the forks for a little shelf to set the can upon.
2) The siphon is packaged in a coil and it was nearly impossible to use out of the package as it would want to return to the tight coil. I laid it out flat under some lumber for a week or two and removed the coil memory. Now it works great.
So, for less than $10 ( that's saying something with today's prices ), no motor, no batteries, no drill, nothing but a line with a little check ball, refueling is simplified.
That’s Cheating! 😜
10,538
After doing some research last year I bought a John Dow 106 gallon tank with auto shut off nozzle from Home Depot. The price of these has jumped significantly over the last 12 months. I paid a little over $1,000 delivered to the local store last year. I made a steel dolly/cart for it so that I can roll it to the front of the garage since neither of my tractors will fit in the garage and the hose is only 13ft long.
Last summer I took delivery of an LMTV M1078 that has a 60 gallon fuel tank. I think of that as being a rolling fuel storage system as well.
jyoutz
Jan 14, 2019
3,535
2,619
Edgewood, New Mexico
ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
I'm also a member of the old farts club and had the same issues of lifting 5 gallon jugs onto the hood to refill. I think I have about $150 invested in this (new 55 gallon drum, drum dolly, electric pump kit and oil fill accessories). It has worked out great for me. I just have the oil delivery company fill it when they are filling my fuel oil tanks.
The power plug mates with my 12 volt socket that is mounted on the fel.
3,397
Fueling my B7100 is kind of a pain; the fuel tank is under the hood, but you must lift over the FEL supports, & it has a fuel strainer that slows fueling, plus I ain't getting any younger these days.
After struggling with 5 gallon cans, I found this 2 1/2 gallon. Much easier to lift & control.
Then I added the fuel hose benders and it got even easier.
5,643
I would like to see a video of that operation from beginning to end. I can't imagine starting and ending the flow without a considerable mess.
Interesting. Maybe sometime I’ll video it but it would be a really boring video. Works like this:
1) Step on step with right leg. Put jug on right knee. Use left hand on loader to assist and steady for the actual step to the platform. Right hand carries the jug.
2) Step up, continue motion forward taking next step onto platform with left foot.
3) Stepping up with jug on right knee propels it forward as you step up. Use that momentum to assist in swinging it up to gently set the edge of the jug on the steering wheel.
4) With the jug sitting calmly on the steering wheel, both feet on the platform; everything stable and stopped: take the cap off the nozzle and set it aside.
5) Opening the cap on the vent now or after starting flow is optional. I remove vent cap now.
6) Place left index finger over the end of the nozzle. The nozzle and my left index finger are sized such that this forms a quite effective short duration low pressure valve.
7) Using right hand, tip the heel of the can off the steering wheel, gently sliding it onto the cowl. With the heel of the can in the corner formed by the steering wheel and cowl, slowly tilt the can down while guiding the nozzle into the fuel tank. This particular can just happens to fit the L4701 perfectly.
8) Immediately prior to left index finger interfering with nozzle entering the fuel tank filler neck, remove index finger and allow flow to start.
9) If you didn’t open the air vent previously, do it now.
10) Wipe the little bit of diesel you now have on you left index finger on your pants where there’s already a stain from the last 50 times you did the same thing.
With some minor variation specific to different machines and cans, that basic method of find something to rest it on and use a finger over the nozzle as a valve is pretty much how I’ve put fuel in a bunch of different stuff with a bunch of different cans for a few decades. I really thought that’s just how it’s done unless you had a pump or siphon.
Trying to think of some at least pseudo reasonable way that would make a mess and not coming up with anything. I suppose I could charge up on the platform sloshing diesel willy-nilly like some sort of drunken wild man but that doesn’t seem reasonable. 🤔
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
i7win7
Feb 21, 2020
3,377
3,992
Central, IL
I made a custom pallet for a 50 gal tank. CC $ limit, you may need to run it twice to get 40 gal. then drive to different pump to fill tank or use 2nd CC
