Figured to remove box blade and then mount and setup the new Landprice RC1248 this afternoon and then to go down and do some cutting.
A real PITA. Almost sorry I did not buy another Frontier. Frontier's is MUCH easier to setup and works with QH hook left in place.
Had to remove the top hook on the QH. The RC refused to lower below about 3 inches up with the hook on the swing spot where I used the hook on the Frontier.
Fortunately, I had a U adaptor for the QH top hook. The one photo shows it in place. The other 3 implements worked with the top hook in place where it could hook the swing spot (just below top holes). Now, I'll have to run the adaptor for everything and hook the lift arms first instead of the hook first.
All the bolts were tight such that the swing gizmo would not work. Loosened them. It'll likely give a lot more movement of the rear of the RC than the slide gizmo does on the Frontier.
The tiny bolts holding the tail wheel adjustment are a PITA vs. Frontier's big, long swing bolt and 2nd bolt to adjust height. Hopefully, I won't have to touch them again. The tail wheel on the Frontier has to be removed to remove the blades on the RC. Not so on the Landpride.
